Almot
Nov 09, 2013Explorer III
Tomboy13 wrote:
When on the SHORELINE...should Home (Coach) BATTERY be disconnected? OR Stored?
Leave them connected. Shore power will recharge them, though poorly. AC/DC converters in RV are usually in the wrong place, too long and thin wire, not enough volts for proper charging. Also, as Roy mentioned, some are cr-ap to begin with, and won't taper the voltage when battery is full, and may overcharge the battery.
Tomboy13 wrote:
When camping without shoreline...Batteries run down at night if heater left on...even set @ 70* is there a trick to not running your batteries dead while camping
The trick is called "catalytic heater". There are 2 of them around, Platinum Cat and Olympian. Cat is better. Either one will save both propane and battery power.
Another trick is called "add one more battery".
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
