BFL13
Nov 11, 2013Explorer II
lanerd wrote:
The switch by the door is commonly called the "Salesman's Switch". Typically used to turn lights off and on .......
Your converter will continue to charge the batteries while this switch is in the "off" position.
Ron
Not usually AFAIK. That door switch operates another switch (solenoid type) that does isolate the converter from the batteries in the MHs I have seen and read about on here.
On shore power with that switch made, the converter will still run the 12v stuff in the RV, but not be able to charge the batteries. I don't see how that door switch can work the lights when you are on shore power.
With no shore power and that door switch made, the batteries will be unable to run the RV's 12v stuff (except anything direct wired to the batteries, like jacks, etc.) Now that door switch would work the lights.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
