tsweez's avatar
tsweez
New RV'r - Batts + Chargers + Inverters = clueless
First, I am a newbie in every sense of the word. New RV'r and new to the forum. So if you see any flaws in what I'm trying to do, please let me know.
I recently purchased my first RV. A late model, 91 Mallard Sprinter. Eventually I'd like to have it setup with solar, an inverter, and enough batteries to hold me for several days. But for now, I have a generator and a dead 12v coach battery in the engine compartment.
I thought that rather than replace the existing 12v, I'd build a vented battery enclosure in the basement area adjacent to the generator. The idea is to start with two 6 volt Trojan T105's or similar and have enough room to add two more once my battery needs become a bit clearer.
My first challenge is to better understand what I need to do as it relates to the simple relocation of the exiting battery to the new location. I know the existing coach battery charges via the generator and the engine via some form of isolator, but I'm clueless what I need to do to simply replicate these functions once I move to the new coach battery location. Any feedback is most appreciated.
For reference, the plan is to add a 1500w PSW inverter, battery charger, and transfer switch (All GoPower Products). The goal is to:
- Draw and charge from shore power when plugged in
- Draw and charge from gen when running
- Charge when engine is running
- And eventually, charge from solar
But all that comes once I simply setup the new battery config.
Thanks again, and kudos to all of you for having such a great community here. The information has been absolutely invaluable.
Thanks,
Tim
  • Thanks donn0128,
    I'm assuming I have do have an outdated 1 or 2 stage charger but have absolutely no idea. I don't even know where to look. I had planned on using a GoPower battery charger as part of the inverter and transfer switch install. I have no problem making that particular purchase sooner than later if necessary.
    Regarding batteries, I'd very much like to go with four if I can get my hands on either the Sams or Costco batts. There are no Sams Clubs in my area, and I have yet to venture to my local Costco. In the end, the goal is 4, 200+ Ah batteries series/parallel.
    Regarding the inverter, I'm planning on my laptop, at least one TV, sat controller, my daughters xbox, and a variety of misc routers, 2g/3g Boosters, Wifi ranger, etc. I tried to do my best to size the inverter for what I was doing.
    Thoughts?
  • First thinga first. What converter do you have? It is probably an outdated 1 or 2 stage, you need to change it to a modern three stage. Depending on what you paln to run the inverter might be overlkill. A 1000 watt will power the TV and sat receiver if thats what you want. As for batteries, go for four. Also s ams club golf cart batteries seem to be a better option per Amp of capacity. Unless ypur gping with a residential refer it runs mainly on gas so that is nothing to worry about.
    So, exactly what do you think your going to run off the inverter?
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
