tedp's avatar
tedp
New smart TV
I've installed a new Samsung smart TV in my motor home and I cannot get it to see the cable channels. I know the cable works because I can get my old "dumb" TV in the bedroom to see all the cable channels. I know the coax between the switch box and the smart TV is good as I can get over the air channels using the antenna. Could my switching box be bad? Any other help would be appreciated.
  • Retired JSO wrote:
    Run a length of coax from the working bedroom TV to isolate where your problem is, wiring or TV.
    Ran coax from the campground cable direct to the back of the smart TV and it worked. So it means it's in my switch box I guess. Right?
  • jdc1 wrote:
    If you are using a "smart tv", why are you not streaming it via your wifi?
    Not good enough wifi strength
  • jdc1's avatar
    jdc1
    Explorer II
  • Run a length of coax from the working bedroom TV to isolate where your problem is, wiring or TV.
  • Have you changed the input on the TV to the COAX input and scanned the channels?
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 19, 2026
