lem55 wrote:
Let me add a little more info on the equipment in question. My house converter/charger is a WF-9845 which has 3 step charging Bulk/quick charge 14.4
Normal charge/13.6, then a trickle or float charge 13.2 volt, but nothing in the manual does it mention anything about "Lithium". The battery is a 200 AH with a
2560 WH. If this helps. Thanks for the good info,
That WFCO is fine.  Not sure if it will ever see 14.4 volts but is fine if it does.  There is no metric or lithium electricity.  It is just about voltage and the WFCO falls well within range of the battery specifications.
Connect the battery and enjoy some camping.  Nothing is immediately needed to change.
