- BFL13Explorer III suppose some did have 12v. We had a 16 ft 1972 Holiday, got it in 1984 in NS and towed it across country to BC. (With a 1979 Ford LTD sedan)
I remember it had four fuses in the 120v panel for shore power and that propane lamp over the table in front. Don't remember a battery at all. It had electric brakes and the car had a metal plate above the brake pedal that worked the trailer brakes when you stepped on it. (I guess that got the trailer stopped first now that I think about it) Also had a sliding over kind of lever in a box on the front seat you could adjust the trailer brakes with manually. Same as on a modern brake controller for that part. I never used that ISTR.
The OP could say if that one has original 12v.
EDIT--ISTR you pumped up water to the kitchen sink by hand. Can't remember if it had a shower in the bathroom or how it would have worked for pumping water if it did. It had a real bathroom at the back with a toilet and sani-dump outside like they all have now. Can't remember how the toilet got its water.
EDIT some more--The Ford was an early idea for a Crown Vic, being a tad smaller than the earlier Fords. It had a 351 engine. But you had to be ready to say it was a "Windsor 351" and not one of those phony 351s made in the States somewhere :) - MrWizardModeratorBlf
I really sure that a 71 Holliday has a 12v system
Those were a pretty nice travel trailer at the time
Not a pup not a mobile home - RJsfishinExplorerIf it was me, I'd make it all 12 volt.
If you don't want to mess w/ or maintain a battery, you don't have to. To operate on shore power, all you will need is a new converter, which does not need a battery,......or even use a battery charger of adequate amperage to operate the 12v items you choose.
If you need to leagalize the breakaway for towing, you can use a 12v lantern battery, as many do on non powered trailers. - amyj72177ExplorerOK you have all given me a lot to think about and change thanks.
- BFL13Explorer IIThose old TTs had only 120 and propane (including a lamp above the table in front), no 12v. Did have electric brakes. But now you need a breakaway system for the brakes so a 12v battery is compulsory. How to keep it charged up? A converter.
With the battery and converter, now you can add 12v things the original never had. - MrWizardModeratorlights etc are already electric
12v electric, the built in converter, should probably be replaced with a new one
if you means residential 120v fridge, many of us have done that, electric heat might get expensive, depending on where you are at, and a propane furnace is always a good back up option, a heat pump instead of the roof top A/C
will give a/c or heat down to about 40 degrees, below that you will need the furnance or other form of heat
and electric cook top or MW is easy to use
I suggest, if your going ALL electric for major appliances and heat
that you get an electrician to install a 50amp RV service, instead of the orginal 30amp service
there is no need and its a lot of trouble, to rewire all the lighting to 120vac
just replace the lights with some 12v LED fixtures and continue to use 12v
with a modern converter 120v to 12vdc, (Not Inverter) different device , you don't have to have a battery,
but IF there is a shore power failure, No lights, No water pump, No furnace, unless you have a battery
an INVERTER uses battery power to create 120vac power for things like the TV, when there is NO shore power or generator
like late at night in a campground with no hookups
or during a power failure
how long you have power depends on how many batteries you have and how much power you are using, you can watch tv for a number of hours, but electric heat or A/C is almost impossible on battery power
so a propane heater or furnace is a pretty god idea for 'Most' people - DrewEExplorer IIUsually the lights and vent fans are all 12V in a travel trailer, besides the things others have listed (water pump, various appliances you're likely replacing, the radio if there is one....)
Rewiring the lights for 120V would be a rather tricky process unless you have the walls and ceiling apart already. The existing 12V wiring would not be acceptable for 120V use. - 1492ModeratorMoved from Forum Technical Support
- kerrlakeRooExplorerThere are a few systems that are specifically 12 volt. Water pump, furnace fan, etc. Yes you could eliminate the 12 volt circuits, get a 12 volt converter similar to what folks used to use to power a cb radio or car stereo in their homes, but purchasing and installing it will largely consume any savings you may be envisioning.
- 2oldmanExplorer IIRestoring, not resorting.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
