RJsfishin's avatar
RJsfishin
New TV (tel) No Work on DVD Player
Installing new Samsung tv, but before final, I plugged it all in. All works except existing non HD DVD player. Its playing fine on the old tv right now,....just 2 RCA plugs, LH audio, and video.
New tv appears to have the same "aud vid" jacks, w/ an added comp vid jack. I used LH audio and video jack, to no avail. I can't even get audio, leads me to believe its a "source (input) problem. I went thru all the sources, tv, pc, HDMI, component, etc etc, nothing but "no signal" and "no cable connected".
Any ideas ?? short of finding a 10 yr old kid to come fix it ??
PS open box special, no owners manual,.....not helping either
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    BFL13 wrote:
    Some DVDs need to be "set-up" to match the TV
    None that I have ever seen. Other than 3/4 if you have a built in modulator and I have never seen that either.
    For the O/P... I would upgrade to a 3-cable hookup L R Video
    It may be it wants both sound channels
    My samsung takes A/V in just fine.. Just have to select it.
  • I got it !!
    Had to use "composite video", and LH audio jack.
    I thought I did that, but must have had the white/red reversed.
    Thanks all,....and the OM link
  • RJsfishin wrote:
    Installing new Samsung tv, but before final, I plugged it all in. All works except existing non HD DVD player. Its playing fine on the old tv right now,....just 2 RCA plugs, LH audio, and video...PS open box special, no owners manual,.....not helping either
    try looking here for your owner's manual
  • This is a new 22" Model ?? (have to look)
    It seems I'd be working w/ the A/V source, but I guess not ?
    JiminDenver wrote:
    Maybe the non HD dvd wont work if the TV settings are set to HD.
    I have a 19 inch Samsung and will see if I can find it's manual OR if you tell us the model I can look it up for you.
  • Maybe the non HD dvd wont work if the TV settings are set to HD.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
