- bgumExplorerJim Varney died in White House Tn.
- GjacExplorer IIIIt sounds like they are plating the lead over a light weight plastic substrate. Seams like it would be cheaper to mfg and lighter. Didn't Jim Varney die after he went to Washington?
- wa8yxmExplorer IIIGenerally "Scalable" means up but can also mean down.
If this works and is not a whole lot more expensive it may put traditional lead acid out to pasture (It won't put the companies out of business because I suspect it can be made on the same machines) If you can pack say 85 AH into say half the weight I might pick up a few feet per gallon on the old MPG chart. - MEXICOWANDERERExplorerCoated silicone solar wafers? Rubber Baby Buggy Bumpers. Less lead means more CCA and cycles.
A Jim Varney interlude
Having RV issues? Connect with others who have been in your shoes.24,352 PostsLatest Activity: Jan 21, 2026
