Homestead_or_Bu's avatar
Jun 06, 2016
Newbie -help? LP tank rust and service valve
Hey every body. Newbie here.
I have just made my first foray in to RV land. Glad to have found you all! I'll put a little about my rig and me down below just to give you a peek here.
This, my second post on this forum, is regarding my on board motorhome LP tank--
Pre-purchase inspection in FL passed a drop test fine. They cited no issues with the system, and they did cite really detailed things, even like a discolored AC cover.
Second place I took it to after purchase, about 2 weeks later says the service valve is bad and they can't even test it until that is fixed - $450 price tag for that. But part delivery would take too long so I headed up north and just didn't use it.
Third place I take it to near home (upstate NY) says tank is corroded and they don't know how long it will last- probably ought to replace it - $1250 price tag! ( for tank and labor) Yikes.
I called up first 2 places and they each said tank itself was okay.
What's with the 3 different opinions? and more importantly, how to discern whats really needed?
I don't know if it is just surface rust or pitted. I will go to the shop and have them show it to me.
Well, I sure don't want to be foolish with an LP system because of potential danger, so I wonder if I can do any of these things - find a cheaper tank, aftermarket - or even wire brush the heck out it and use a de-ruster or rust converter paint - or even a salvage place that might have them - or even an alternative "out of the box" repair place. Not sure where to start. Right now I feel between a rock and a hard place., but hoping you all can shed a little light.
Many thanks in advance, Jenn
My RV adventure -
Plan is to travel and then find land to create a permaculture homestead, living in the RV while building natural building. Big adventure!
I have an old 1998 Coachmen C class 22 footer. I have put pretty big bucks into it already, and looking to do a few things myself, because man o' man is RV tech labor expensive! I value their work, but honestly I feel I could do some myself. I'm handy, and gotta slow down the money pipeline.
  • Instead of going to a RV dealer I think I would be calling an independent RV mobile service technician. I have used them several times in the past and found them to be honest, proficient, and easier to get service from. They even come to you! :)
    Barney
  • Thanks DrewE. I really appreciate the response.
    Yep, all RV dealers. I like the idea of propane dealers. I have tried a couple Propane dealers, but so far no luck for RVs. They don't do them. I will try more such places. I wonder what other kinds of places that service propane tanks might exist that could fill and tell me if I needed a service valve repaired ...hmmm...???
    (I'm in upstate NY)
    Do you know exactly what I'd be looking for on the tank to determine it's integrity? Would that be pitting, or?
  • DrewE's avatar
    DrewE
    Explorer III
    What kind of places have you been taking the RV to be looked at? If it's an RV dealership or service place, try going to a propane dealer, the kind of place with trucks that deliver propane to houses and rent tanks and such. I would expect more reasonable prices (if it needs a new valve) and more competent servicemen since that's what the specialize in.
    Repainting a built-in tank is certainly something that can be done yourself, assuming the rust is not compromising the integrity of the tank. I generally gather that failure of built-in tanks due to corrosion or whatever is not at all common. Valves etc. needing replacement is somewhat less rare.
Having RV issues? Connect with others who have been in your shoes.24,360 PostsLatest Activity: Mar 27, 2018
