Big_Katuna
Dec 12, 2018Explorer II
Everything should work on 20 same as 30. If you try to run ac as Mex said, you will pop breakers.
To repeat, your rv DOES NOT have any 220 volt circuits. If you apply 220 you will burn stuff up.
If you have dead circuits start looking for tripped breakers, etc. Lights not working might be because they are 12 volts so check your battery and charger/ converter function.
On a trailer that old you will probably only have a few 120 outlets. Lights, fans, etc run on 12 volts and will have a separate fuse panel.
Please keep us posted.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
