time2roll
Dec 13, 2018Nomad
DutchmenSport wrote:Yes that is true. Both are available. Standard NEMA 14-50 power.troubledwaters wrote:
Some people should not be giving electrical advice; they don't know what they're talking about. There definitely is 240V available in a 50A RV; it's just not generally used.
So are you saying, I can plug in a 220 volt appliance into a standard 50 amp outlet at a campground and get 220 volts, yet take a "normal" 50 amp plug for an RV and plug into the same outlet and get 50 amp / 110 volt?
From this common service we can draw 120 or 240 volts.
Even clearly says it right on the connector:
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
