troubledwaters
Dec 13, 2018Nomad
Do you have two 120V hots, a ground and a neutral in your splitter box? If not, you got a problem right out of the gate. Your 30A only required one 120V hot. Now you need two.
Secondly, is the wire sized correctly for 50A? Your 30A required smaller wire, the 50A requires a larger gauge wire.
Conduit size may also be an issue (if the wire is run in conduit).
Many issues to consider, it's not straightforward.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
