healsing's avatar
healsing
Newbie! 30 amp to 20 amp converter
HI folks,
I'm brand spanking new to RVing.
The trailer I am attempting to make "usable" is a 1988 Companion Classic. Needs work.
My question: when using a 30 amp to 20 amp plug converter does it follow that a portion of the original 220 circuits will not work. Or does the adapter send current to both sides of the 220. I do not have the option of a 30 amp 220 connection. Only 20 amp 110. Some circuits are not working and I want to determine if this is normal or a malfunctioning adapter.
Thanks!!!!!
Rob
  • Hi Rob,
    Welcome to the forums.
    RV's almost never use 240 volts.
    There are two legs of 120 volts each on a 50 amp rv service
    When using an appropriate adapter both legs will be powered.
    On a 30 amp RV there is only one leg and it is 120 volts. The adapter simply provides a way to plug into a 'standard' house outlet.
    NEVER plug a 30 amp RV into 240 volts or you may let out the magic blue smoke.
    I hope this helps.
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 20, 2025
