ScottG
Jul 31, 2017Nomad
A fridge runs about 50% of the time. If you turn it off comepletely it will warm up inside quickly. Why woldn't it? It's only insulated with an inch (at best) of styrofoam.
I once accidientally turned off the fridge just as we set out on a two hour trip. The outside temps were in the middle 70's and when we got to our CG, the beer I pulled out of the fridge was noticeably warm.
It may be ok to run with it off if you don't have anythig perishable but if you do, it will spoil if driving all day.
Run with the fridge on propane. That's what it's designed to do and is both UL and (better yet) CSA approved to do so.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
