time2roll
Mar 25, 2019Nomad
You are just burning down the surface charge that accumulates while charging. The controller indication is not designed to be accurate with a load on the battery while charging. Your battery will continue to drop until you are down to 12.7 volts that represents full charge. At that point it should hold much more steady down to 12.2 volts representing 50% under modest load.
The 12 Volt Side of Life
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
