Shadow Catcher wrote:
The claims for 20 to 43% increase efficiency are bogus which makes all the other claims suspect.
We have a high voltage panel that typically puts out 43V at the controller in full sun with no tilt. It is run through a Morningstar Sun Saver MPPT controller and I monitor using a Victron battery monitor. The high voltage means you get some usable current even in shaded areas. Just for fun I measured voltage from a full moon and got 12.7V.
The review in the Wind & Sun forum http://www.wind-sun.com/ForumVB/showthread.php?17511-Eco-Worthy-20a-MPPT-charge-controller-review
The RV net forum discussion http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/26464298/srt/pa/pging/1/page/2.cfm
I am the author of both threads and I am thrilled with my little el cheapo controller. The reason I didn't go even cheaper is many of those are labeled as MPPT but a look at the guts proves it isn't so. ( at least at that time) A look in the Eco-worthy shows the MPPT coil as well as the temp sensor that I can confirm at least works.
