KD4UPL wrote:
A cheap (poor) charge controller can cause lots of problems. It's not the place to skimp. You want one that has programmable charging set points so you can charge your batteries to the manufacturer's specifications. A poor controller can overcharge or undercharge your batteries. Also, an MPPT controller will allow your panels full output to be better utilized than with a PWM controller. If you're going with a larger (less expensive watt/dollar) panel it will likely have a high enough Vmp that you will need a MPPT controller anyway.
RV usage, I guess because of price, is one of the last places PWM controllers are installed anymore. The home, cabin, grid tied solar industry has almost completely moved to MPPT controllers for all of their advantages.
I would highly recommend Blue Sky charge controllers.
FYI, there are fully programmable controllers out there for as cheap as $12.50.It has so many adjustments, I don't know what 1/2 of them are for, but I know the first one (of 10) was adjustable for 5 different types of batteries. It worked perfect, but its only a 10 amper, so its now setting in my solar acumulation box.
The $10 (non prog) 15 amp ebay china controller I have now, brings my batteries into float mode at exactly the same voltage as my PD 9245, so thats good enuff for me.
Just because you spent big bucks for morningstar, doesn't mean you have to to get a controller that works just as well,
But, being a short timer, I can't speak for the longtivity of the cheap priced controllers, but I will tell you that I really couldn't care less, when I can buy 2 dozen spares for what you spent on a morningstar. And I can change it out in 3 minutes.
Now, having said that, you will notice that the purpose of my above post was to advise a nuby like myself to think about handling and storage of smaller panels verses large heavy ones,.....not to sell cheap china controllers.
