aruba5er
Jan 11, 2014Explorer
Which is the FIRST outlet then the SECOND and so on? It should be required to provide a secematic of how the wiring was done.or photos before the walls go on. Most wiring I am familar with on an rv is Vampire connections where the wire is pokked into the back of an outlet and a cover snapped over it. If that outlet fails the others down the line still work. GFCI outlets still have screws so maybe the load has loosened up a wire and has caused the trouble. I would check at the gfci first. Pull it out and test, just don't look at it. I've changed too many that have reset and still nothing comes out.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
