time2roll
Nov 14, 2016Nomad
If the voltage output mirrors the existing alternator output it would seem to be plug and play. Easy to verify after the money is spent and equipment is installed. Best to know before hand.
Does pulling power direct off the stater bypass the alternator current limitation? Or are maximum amps limited by a maximum field current? I really do not want to burn something up on the first day.
Does it need a monster heat sink if alternator is half the rated capacity?
