bob213
May 22, 2013Explorer
Most batteries have a resettable breaker usually mounted on the frame near the battery. Some you push to reset, others require the battery to be unhooked and then rehooked. Use your volt meter to see if you have 12v at the block by the back of the refrig. There's are fuses on your control board(black box by the back of the refrig)that usually has two fuses in it that controls the eye boards for the refrig and a/c.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
