ktmrfs wrote:
Coffee, toaster on a single 15A breaker is really likely to end up tripping the 15A breaker. each could easily draw around 12A. quickly will trip a 15A breaker.
Sorry, but that's not true... Any molded case circuit breaker (like in houses and RVs) will continue to operate indefinitely at it's rating. You should be able to run 1800 watts continuously without a problem and if the 15 amp breaker does trip, it's faulty. And that is *IF* there is 120 volts at the appliances (that is it's rated operating voltage as per the label) and often the voltage is less, and sometimes a lot less like below 110 volts.
The other thing to know is that breakers do NOT trip as soon as they hit their rating. The have an inverse -time current characteristic as shown in this industry standard tripping characteristic graph. The time at which they trip depends on how much the current is over it's rating and for how long. The shaded area is the min. & max trip times. You could for example have 20 amps on a 15 amp breaker run for 1 to 5 minutes before it trips, or 17 amps would run for at least 2 min. and maybe not trip at all. The graph is showing that current twice a breaker's rating would continue to run for between 9 & 35 seconds before tripping (yellow line).
In most cases, the short duration of a toaster or coffee maker won't trip a breaker if it causes a slight overage on a breaker. And except for AC units, the lower the CG voltage is, the appliances will draw less current and it's even less likely a breaker will trip.
If you have a good stable voltage at home or elsewhere, try plugging in say 2000 watts total (16.7 amps) on a 15 amp circuit and see if the breaker trips. It should not trip before approx. 3 min., if it trips at all.
This is all assuming your SCD RV receptacle(s) was wired correctly at the factory... :)
