GaryS1953's avatar
Jul 27, 2025
Solved
No 12 Volt without converter
So my recently acquired 2002 Jayco Qwest 253D fiver suddenly has absolutely no power when not connected to shore power.  Both batteries are showing 12.5 volts, so seem good, but not getting charged b...
  • opnspaces's avatar
    Jul 29, 2025
    If it was me I would take a picture of all the fuses so I know what goes where. Then pull them all out of the panel. Remove any and all screws and open up the panel so you can see the battery wires in the back. From there see if there is a hidden fuse. You should also see the larger wires that go up to the batteries. Put a meter on those wires and see if you get battery power there.
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 29, 2026
