mark1967usafExplorerMay 13, 2014No 12VDCHello! I have a 1998 Winnebago Chieftain 36WL Diesel Class A. I have no coach power. It worked one day then nothing. I checked my batteries, no voltage. I plug in with shore power, nothing. I disconne...Show More
camperpaulExplorerMay 13, 2014The inverter/converter is a dual use device.When in converter mode, it converts "shore power" to 12Volts DC and charges the battery.When in inverter mode it makes 120Volts AC.If you are measuring zero Volts at your batteries, you have destroyed them and you will need to replace them.You will need to connect the I/C to the battery. Before doing so, measure the output of the converter to determine the correct polarization.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 11, 2026
Related ContentNo 12VDC PowerCPAP 12vdcDometic dmc4101 12vdc fridge not cooling and light blinkingFire in the 12VDC systemHOST Mystery 12vdc power port!!!???
