Clay L wrote:
If the converter works on the genny it should also work on the shore power if the transfer switch is working. If the 120 vac outlets work on shore power then the transfer switch is working.
Do you have you have an inverter? If so some of the ac circuits may go through the inverter and the breaker on it may have tripped.
Thanks for the reply, converter is working, found wiring diagram on back of lid and do not have shore power 120/120 going out. Will now order transfer switch after calling both WFCO POWER CONVERTER and, PROGRESSIVE DYNAMICS AUTOMATIC TRANSFER SWITCH companies.
Thanks to all that replied; that is what makes this a great forum.
Terry
