Ray It appears you purchased\installed a PD9260 Correct? What does the statement "puts charger out 12.8" mean? Are you saying you only see 12.8 volts on the battery thats connected to the PD9260? If so then your PD9260 is not functioning. You should at least see 13.9 volts DC when that battery is connected.
