theoldwizard1
Oct 22, 2016Explorer II
j-d wrote:
Seems common for coach builders to use the Trailer part of the wiring harness for lights on the coach body. Check for fuses called Trailer. Then for why it blew.
If this is true, then be aware that on Ford's all "triler" lights use separate relays and fuses.
Check fuse #11 and #39.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
