deprived
Oct 28, 2016Explorer
beemerphile1 wrote:
Have you tried WD40 on the hazard switch as I suggested? It is a known problem with Fords. You push the hazard button to use the flashers, push again to turn them off but the button sticks and the brake lights don't work.
The entire multifunction switch has been replaced. Also, I get proper voltage at fuse 39 when the brake pedal is applied. I found the grounded resistor shown on the schematic, which is a start. Right now I'm just trying to physically locate the wire that runs to the brakes.
Good suggestion about the switch, though . A stuck switch would definitely interrupt the brakes!
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
