MNtundraRet
May 04, 2017Navigator
Did you check the battery ground wire connection? It may be loose or corroded.
Also; did you read the battery voltage with a volt-meter before plugging into shore-power? Reading the battery after plugging into shore-power should read around 13.7 volts while charging or 13.2 volts if battery was actually fully charged.
I suspect the battery may have almost discharged.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
