westend
May 04, 2017Explorer
Make sure the "battery-converter" switch is in the correct position. You may wish to jumper across that switch to see if it has failed.
Reading voltage measurements with a low voltage system can be misleading. You may have 12.5V available but not enough amperage to drive the appliance/bulb. A 12V test light is a good tool to have in this situation.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
