landyacht318
May 29, 2013Explorer
I have the schumacher sc2500a which is no longer made.
2/12/25 amps
I use it as a converter on the 12 amp setting.
The cycling compressor fridge or the cycling mattress heating pad easily throws the charger into fault mode on 2 or 25 amp settings.
Even turning off smaller non cycling loads like my .9 amp tv can cause it to shut off on 2 or 25 amp settings.
Rarely, the 12 amp setting also decides it does not like changing loads on the batteries.
The fan is annoyingly loud.
I'll probably get a PD9260 before next winter. Generally this time of year I never need anything but my solar to replenish the batteries
2/12/25 amps
