MrWizard
May 21, 2023Moderator
What is the voltage at the batteries, does your system have a low voltage cutout between the battery and the control box? Unusual but possible, what is between converter which is using shore power and working, and your batteries, both sources of 12v power should be connected to the control center, there is a break in the circuit some place, like possibly the battery disconnect relay, these latch in position wether on or off, it's in the off position either its stuck, or the on off switch is not supplying the on signal, that relay Should be in the control center, if it's not, you need to find it
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
