1099
Aug 01, 2026Explorer
No DC Power
Lightning hit near our stick & brick recently and damaged some things in our home. A few weeks later I pulled my 2011 / 34SB3 Cameo Carriage out of the barn and was getting it ready for the season. K...
After re-reading I definitely think it's the batteries. Despite being new batts, you said the charger was fried. So, those batteries sat with likely parasitic draws and nothing to re-charge them. If they went to a complete discharge, they are toast. I had something similar happen years ago, brand new batteries completely discharged, my charger wasn't working and they never recovered.
Way, I took the new batteries out and had them checked at the place I bought them. They say there good but run way down. They charged them and I re-installed them…. Tomorrow morning while it’s a bit cooler I’m going to take the 2 batteries out of my F350 and put them in the RV and see what happens….Thank for your help…. J
Running lead acid batteries “way down” for even a couple days toasted them. If they are Lithium they will be fine. You are wasting lots of time. Buy a Lithium battery and go campin’.
Sounds like a plan. RV voltage is finicky and agm batts drawn down more than 50% causes permanent sulfation and usually don't recover enough to run the 12v system.
