dougrainer
Mar 20, 2016Nomad
Your model DOES have the Battery disconnect switch. THAT switch is by the entry door steps. It will be labeled Battery or something that indicates a Battery switch. IF that solenoid is bad or not turned ON, you will NOT get battery power to the Coach systems. Your year model, I believe that Battery solenoid is at the LF battery fuse compartment in front of the LF tire. That entry door switch turns the Battery solenoid ON. It is not unusual for a motorhome your age for the solenoid to be burnt out. Doug
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
