dirtroad2
Apr 17, 2016Explorer
Update on this issue. I never found a salesman switch or a solenoid. I did find the circuit board by the left front wheel. There was a 50amp breaker on the back side of the circuit board with a wire that said to inside fuse panel. the breaker was good and I had power leaving the breaker to the inside fuse panel. I tried to follow the wire but I could not it was bundled with others and disapered into the frame. I then went to the inside fuse panel started to follow the wire from there but again disappeared into the back body cap. I opened the rear engine compartment and found a service panel to the engine air filter. I removed the panel and found 2 red wires with eye lugs on them taped together. No bolt holding them together just loosly taped. I split bolted the wires together and I now have 12volts to the inside fuse panel and everything works.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
