allredc's avatar
allredc
No gas coming out of oven or stove
we have a real head scratcher we need some help with.
we have a Wedgewood vision 3 burner stove in our 2016 Gateway 5th wheel. Everything was working great.
Then a few days ago we went to turn it on to cook dinner. Nothing
none of the burners will light or the oven.
Both propane bottles are full and I put in a new regulator for $60.
I tried switching bottles same result.
no gas coming out,cant even light the pilot light on the oven with a lighter.
Anyone have any ideas?
Thanks!!!
  • Is the Oven in a slide out? If so, then I will bet the LP line is kinked under the slide out. Other LP items run? Doug
  • Try and unhook from the tanks and leave the burners on for 5 min. Then turn the burners off hook up the tank and try it again.
  • Maybe check for a kinked hose, that turned out to be the cause of a similar problem we had.
  • Was it on before? If left off for several days you may need to let it re-fill the lines, could you smell gas?
