philh's avatar
philh
Explorer III
Mar 07, 2021
No gas flow to oven
Stove works fine, in two years we've never used the oven, and the one time we attempt to use it, it doesn't work.
Suggestions? Not smelling propane when it's on.
  • philh's avatar
    philh
    Explorer III
    beemerphile1 wrote:
    Did you push/hold the button? Did you light the pilot?
    That was it, thank you!
  • philh's avatar
    philh
    Explorer III
    That was in fact it. Beautiful flame now, thank you
  • philh's avatar
    philh
    Explorer III
    DOH, maybe I should read the instructions! Never considered holding in the knob.
  • wnjj's avatar
    wnjj
    Explorer II
    This. There will not be gas flowing to smell unless you hold the knob in to supply gas to the pilot flame. Once lit, the heat from the pilot will allow the main gas to flow when you turn the oven on.
    If you want to cheat a bit, hold the lighter where the pilot flame goes, wait for a bit then turn the oven directly on from there.
  • If you have gas flow to stove top burners you have it available for oven
    As asked...does the pilot flame light off/stay lit?
    Brand/Model would be helpful
  • Have you checked under the cook top for a shut off valve to the oven?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
