Just to update my interaction with Dometic. While failing to find the regulator tube part on line, I went back to Dometic. They said that 50806 was no longer available. I said its a new unit! Then the person looked further and found that that part has been replaced by a new part 50817 which is a whole burner assembly that includes the regulator tube as an integral component! It's covered by warranty. But while I can buy it on line, I can't get it from Dometic because it's a gas part! The unit will have to go in to an authorized Dometic dealer! Remarkable. All this time to find that it is a defective part! As it had to be, given that the 4500 feet stuff was pure BS! BTW Ernie, what instrument did you use to reset the regulator?
