StirCrazy wrote:
your instincts are corect in that atmospheric pressure plays a part but non of your calculations will work if you us 0 as a atmospheric pressure. it is 14.7psia or 101kPa at sea level and at 4500 feet it is aproximatly 12.5psia or 85.7kPa and 10 to 11" of watter colume is 0.36 to 0.4psi so realy at 4500 feet there should still be plenty of differential for it to work, maybe a slight yellowing at the tips of the flames. the problem with atmospheric relief regulators is they do use atmospheric pressure to act on the diaphram, the intent is to prevent an air lock from forming above it and preventing it from closing and it has a neglagable effect, but it is also much cheeper than using a pressure ballanced regulator set up.
myself I would remove the regulator , make a fitting to bridge the gap and try the stove, if it works put a new regulator in. mind you this might be more than you want to do while camping. the other option is to change it out and see how it works next time your camping.
this thread has me wondering if mine is starting to get week, I changed out my main regulator and everything got better but I do have a flame that is a little two yellow but I am under 1000 feet and even when I am at 4500-5000 feet it doesnt change realy, hmm something else to updte now I guess... thanks ;)
Thank you. You are correct, I forgot the 14.7 psi at sea level. Thanks to reminding me what I forgot....
