Just about back together and want to give my assessment of the Dometic D21 cooktop. As all of the foregoing indicates, this item has an issue above 4500 feet elevation, which includes a great deal of the camping here in the West. In this case, the gas to the cooktop was completely cut off at that elevation. Dometic gives no warning on this but hides behind the insistence that this is normal for gas appliances. But were that issue overcome, any buyer should be made aware that unlike other stove appliances, the D21 does not permit the top beneath the burners tp be removed separately. To clean any significant spill, the entire stovetop must be removed and disassembled. And this is a complicated process — much more than removing a couple of screws and lifting it out. Aside from the cleaning problem this presents, it also prevents ready testing of gas fittings for leaks and proper LP WC specifications without pulling the unit entirely and working on it upside down (making the main gas line very difficult to attach without special equipment). BTW, given that Escape RVs are sold directly by the manufacturer who refers appliance issues to their respective manufacturers, there is no help from Escape on an issue such as this. Escape accepted Dometic's explanation of "normal" for the altitude malfunction. As for Dometic, nothing can be done except through an authorized Dometic warranty center which will be a long wait getting in.
