JSS1439
May 30, 2014Explorer
Bill.Satellite wrote:JSS1439 wrote:
Hey all, I have a Keystone Fuzion 310 toy Hauler with a Cummins Onan 5500 Built in generator. When I fire up the generator, the converter doesn't kick in but yet when I plug it up to shore power, the converter kicks in and everything is fine. I checked the circuit breaker on the converter and it has not been tripped. I also checked both breakers on the genny and they were not tripped either. Is there a fuse somewhere I can check that may be blown? Any suggestions are appreciated.
Thanks for your time,
Scott
What about the transfer switch? If no automatic transfer switch there would be some manual device you would need to select. Has it ever worked? If not, do you need to manually plug your coach into the inverter? A switch you need to select?
No switch it's automatic. It's a 2012 Fuzion and when you start the genny the converter always kicked in automatically.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
