RLS7201
May 13, 2022Explorer II
Do you know how to remove the headlight switch? Pull knob all the way out, get your fingers on the back side (flat side) of the switch and push the little spring loaded button and then pull the knob out. Then you can undo the nut that holds the switch assemble in place.
Richard
Richard
