Sjm9911
Dec 27, 2020Explorer
Just have to add, was it working before hand? Is it possable you never turned the bypass off? Always better to check the easy stuff first. You can use a hair dryer to defrost the line. Dont let it sit under pressure, becuase if it defrosts and is busted it could flood you out if your not around.
