S_Davis
Dec 27, 2020Explorer
Wadcutter wrote:Lantley wrote:wa8yxm wrote:J&R wrote:
Hot water will freeze before cold water.
That is a myth
It's not a myth. It's basic high school chemistry
Then you slept thru your high school chemistry class.
Still water freezes at 32 deg F. Remember that from your high school chemistry. So what it takes to freeze water is to drop the temp from its existing temp to 32 deg. That requires a transfer of heat away from the water. If the beginning temp of the water is 60 deg then it requires a transfer of 28 deg to drop the water to freezing. If the water is 200 deg then it requires a transfer of 168 deg. That is simple high school chemistry.
You flunked your class. Stay after school. Re-read the chapter on heat transfer. Do some extra credit work and maybe you'll pass chemistry this semester.
So what happens if there is less water, does it freeze faster?
