ashlatz's avatar
ashlatz
No hot water pressure
On a recent trip we suddenly lost hot water pressure. I have an older unit it's a 1997 Damon daybreak. The cold side works fine. I don't see any leaks and ever thing seems normal. Tonight I went under the sink to look at the three valves that I have . I ended up Turing what I believe is the hot water bypass valve. Once I did this I had cold water coming out of the hot water side. Does anyone have any suggestions. Thanks for the tips in advance .
  • Would the line connect in the back. If it does how do I even get at it there is no access from outside or under the sink
  • On the water heater where the hot water line hooks to the heater.
  • Where would the check valve be located . I don't see anything on the front of the heater ?
  • full-timer wrote:
    Sounds like the check valve at the water heater is plugged up or broken.
    He is correct! I recently had exactly the same issue. I replaced the plastic check valve with a brass check valve - problem solved!!!
  • Water does come out of pressure relieve on the heater unit. When I open it
  • Sounds like the check valve at the water heater is plugged up or broken.
  • Bypass connects cold inlet (bottom valve/lie) with the hot outlet (top valve/line) that is why you can get cold water flow thru hot water side.
    Normally with a 3 valve system on water heater no check valves are used.....normally.
    Cold inlet allows water into WH Tank......valve should be OPEN
    Hot outlet allows water from WH Tank......valve should be OPEN
    Bypass...should be closed (Open when bypassing WH Tank. Close cold/hot valves)
    Something is plugged up.
    Most likely the hot water outlet/valve
    Could be cold inlet....easy to check by opening the Pressure Relief Valve on WH Tank (CAUTION..Water could be very hot and will splash)
    If you have water in the tank (flows out PRV) then you will need to disconnect hot water line at water heater and check for plugged nipple or if hot outlet valve is not opening. (Turn off water supply and have a bucket/towels ready)
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
