kramer45011's avatar
kramer45011
Hot water heater
My hot water wasn’t getting hot. I realized in the morning I was out of propane. Filled. .Org tanks but the hot water heater won’t light now. Any suggestions.l??
  • kramer45011 wrote:
    The red DSI switch never comes on at all (since this started). I can’t even hear the hot water heater trying to ignite
    Then you have a DC Voltage issue
    Get out the Voltmeter and start tracing the DC from On/Off Switch to gas valve.
    Already posted 12V DC circuit so use it.
  • The red DSI switch never comes on at all (since this started). I can’t even hear the hot water heater trying to ignite
  • Ditto on what Old Biscuit said, which is a very detailed and thorough post.
  • Those reset buttons^^^^^^^^^^ are to reset the HIGH Temp T-stats nothing to do with 'lock out'
    High temp t-stats trip at 170*F/manual reset
    Left side 120V AC...electric element
    Right side 12V DC...propane
    'Lock out' happens when 3 attempt to light flame and prove it lit fail
    'Lock out' will trigger the RED Fault Light on switch panel
    Reset by turning ON/Off Switch OFF---wait 30 seconds then turn on
    IF spark electrode is not 'firing' then it could be a 12V DC issue
    The 12V DC set of t-stats are connected via a wire from top t-stat to bottom t-stat...they can burn into
    Could be connection inside junction box on backside of WH Tank
    Could be an issue with the circuit board on backside of WH Tank or mounted close by
    So you need to test where you have DC and NOT have it
    IF you do have 12V DC then.....
    Keep trying to light water heater
    LP System is only 0.4 psi....can take several attempts to get full flow to all appliances
  • Might have "locked out" due to too many tries.
    Depending on your unit...Try pushing the RESET button on the back of the heater.
    EXAMPLE:
  • I tried the running burners on the stove . They worked fine but not the hot water heater. It doesn't even sound like it's trying. If it was pressure ...what's the remedy?
  • Also if the line was not pressured and you opened the tank valve fast the overflow protection device can limit the flow.
  • Purge the line....
    Light a stove burner or two, this will get the air out of the lines and get propane flowing to your water heater.
