the_trippers's avatar
the_trippers
No Maintenance Coach Barttery
My coach battery is on a pull out slide that is almost impossible to pull out far enough to check or add water to the back cells. It's 6-yrs old, doesn't hold a charge, and I want to have it replaced with a no-maintenance type battery, I'm thinking either AGM or Sealed.
I've never had a Sealed or AGM before.
I found information saying that AGMs require different charging voltages or they will be damaged. For Sealed no info found yet.
I'm certain many RV folks have gone this way. Can this be readily done? How about the charging voltage? And is Camping World the place to get it done?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
