Ivylog
Sep 07, 2015Explorer III
To remove just the left cable I would not disconnect the batteries. Just make sure you do not hit the metal mounting bracket while disconnecting. If you need to connect it to the right connection then yes I would disconnect both negative terminals on the batteries because on the right side it's easier to hit something if you are not careful. I would not disconnect the batteries but I work on stuff like this all of the time and learned a long time ago how hot a wrench can get when you short it.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
