Ivylog
Sep 07, 2015Explorer III
The rubber mat burned the coil up and it's blowing the protection fuse. Here is a $58 replacement and says it's a latching relay... only requires a short pulse of power to activate. Connect the two big cables either side together and you will be fine until you can replace it.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
