BFL13
Jun 18, 2019Explorer II
Damdifino wrote:GordonThree wrote:
Put a volt meter across the panel itself, without any connection to the controller.
Maybe a bad or disconnected diode?
So just stick a probe into each lead? (Excuse my ignorance.)
Tilt and aim the panel at the sun near noon, no clouds. Panel Voc about 22v so with heat from sun, you should get about 20v Voc. Switch meter to amps and now get approx. 6 amps Isc. Panel good, so check your wiring.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
