pianotuna
Jun 19, 2019Nomad III
Damdifino wrote:pianotuna wrote:
Hi,
What is the battery voltage?
Double check to make sure input to the controller is correct polarity and correct terminals.
Voltage at the controller is 18.63 (or -18.63 depending on which probe on the micrometer.) What would happen if I just switch the panel wires leading into the controller. Will that fry something?
Very likely.
I wanted to know the battery voltage. If it is higher than the set point on the charge controller--then there won't be any charging happening. i.e. your system may be working exactly as it should.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
